1998 v70xc ac troubles - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 12-09-2015, 09:16 PM
Default 1998 v70xc ac troubles
After over spending at a reputable ac place with a new to me volvo they filled it with dye, did vacuum pressure and everything looks good. Fans work just compressor not engaging. They convinced me I needed to replace one of the computers and I did from a good guy online. Took it back to have installed gratis and still didnt work and they tried convince me the new computer had exact same issue. Didnt seem possible so I contacted my source who promised it was checked and willing to refund me but it's too convenient that they're both fubar. .. ive read somewhere theres a issue w ac somewhere with a connection of sorts please help!
Old 12-12-2015, 12:19 AM
Bump?
Old 12-19-2015, 11:40 AM
Moderator
geez, the computer is probably the last thing I'd suspect. I'd start by jumpering the high and low pressure switches to make sure you don't have a sensor issue. Then I'd check the various relays. Does the clutch try to engage? these ACs are known for having clutch gap issues which can show as the clutch engaging, slipping then disengaging. Could be a failed clutch or wiring/connectors into the compressor too. Did your tech comment on the worksheet about checking voltages at the compressor? Also do you see any error codes like the AC light on the dash flashing etc?
Thread Thread Starter Forum Replies Last Post
1998 V70XC: What is it worth? W.Beetus Volvo V70 5 12-09-2015 09:25 PM
1998 V70XC muffler jpirish Volvo V70 1 10-25-2009 07:37 PM
1998 Volvo V70xc Turbo Replacement liamhenryf Volvo V70 41 05-09-2009 05:07 PM
Stereo install V70XC 1998 tom1568 Audio/Visual Electronics 3 12-17-2008 12:14 PM
2001 V70XC Vs 2002 V70XC, with similar mileage? jklenk Volvo V70 2 08-18-2008 01:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
