2000 xc70
2000 xc70
Please don't shout at me if i in the wrong place or my problem has been covered already i am new to this
My 2000 xc70 has the EML light on the srs service urgent warning message and the air bag symbol on / 2 different problems i know
Anyway i have a cheep obd11 reader when i plug it in it reads 2 codes when i read the codes it comes up with ENGINE / A/T i press delete codes and eml light goes out when engine started switch of resart engine EML back on ???
My SRS is probably more of a problem but SORRY for such a long first question if i get no responce i will fully understand THANKS AGAIN
i
i
https://xemodex.com/us/knowledgebase...c70-1999-2000/
For the SRS warning - You're in GB - if your 2000 is a P2 car - that could be a problem in the DIM (the instrument cluster) or if the engine runs normally both could be DIM problem.
First step would be to scan the car with an appropriate scan tool to get an idea of what the car thinks is wrong with itself.
Hi thanks for replying i have had the codes read SRS is is now off air bag in O/S upper piller fault code high voltage or something anyway bad connection .
The other faults are
canister purge (c/p) valve signal
turbocharger( t/c) control valve signal
boost pressure sensor
brake pedal sensor
Now could all 4 of these be the cause of my EML being on or is there more than likely that only 1 is the problem linking them together
I know how to check the brake pedal sensor could this be the problem causing my cruise control not to work but as for the others i am not 100% sure of the location or how to test them if it is at all possible
Also on my brake servo i have the pedal sensor on the left towards the rear and on the right the is another sensor but no wires with a plug on any where any ideas thanks again
brake pedal sensor
Sorry I forgot that in GB you have an Engine Management light - here in the US that's our check engine light. And any of those codes could be turning it on - Erase them and see what comes back first - As far as location and how to test - The free stolen/ hacked copy of VIDA, Volvo's service manual that is available many places, (there's a download on swedespeed) has diagrams and test procedures.
dave_gordon
03-11-2010 08:56 PM
