02 V70 Turbo Hard Start
02 Volvo V70 2.4T. 116k miles. It has a starting issue. Best case scenario, it will crank after holding the key a few seconds longer then normal. Worst case scenario, it will take me several attempts to crank, sometimes requiring me to hit the gas peddle. At times it will also make a quite backfire while trying to crank. After it's running it has no issues. Doesn't seem sluggish or anything.
Does the starter engage right away when you turn the ignition? Is there a delay before the starter engages? Confused here on the symptoms
Yes, starter engages immediately. I meant that the engine turns over longer then usual before firing. I'm leaning towards a fuel issue or timing. Now at times, while stopped, the car will shudder as if it wants to shut off.
DecalService
12-04-2019 10:52 PM
