Leaking Power Steering Rack
Old 01-27-2017, 09:44 PM
Luis Soliz-Flores's Avatar
Default Leaking Power Steering Rack
I have a 2005 V70 non turbo 2.4 with 192,000 miles with a power steering leak at the steering rack where the metal lines enter the unit. Are there seals or O-rings that fail or will this be a bigger issue? It looks like it's only leaking from the lower line but it's a consistent drip, i need to refill the reservoir every 3-4 days even with minimal driving. I added Prestone PS fluid with Stop-Leak but it hasn't helped. I'm going to try other power steering additives but i don't want a patch job but would rather do a proper repair. The attached picture is from the drivers side wheel well. Any help is greatly appreciated.
Attached Thumbnails Leaking Power Steering Rack-power-steering-leak-copy_ink_li.jpg
Old 01-27-2017, 09:47 PM
ES6T's Avatar
Looks like you need o-rings.
Old 01-30-2017, 06:45 PM
Is there a specific part# or specific size for these? Available at any parts store?
Old 01-30-2017, 08:42 PM
ES6T's Avatar
There's a part number but I don't have it. Your local dealer can help you. Should only be a few bucks.
Old 02-01-2017, 11:36 PM
$9.60 at the dealer. EACH!!! Was thinking about trading the car in but I'm keeping it based solely on the fact that it has $10.00 O-rings on it.
Old 11-19-2017, 03:09 AM
hyperiongate's Avatar
I have the same problem. Did the o-ring fix the problem?
ludeless
11-18-2023 07:51 AM
timmins
09-28-2022 02:00 PM
x-angel
05-29-2011 06:13 PM
airmiller44
05-13-2009 09:48 PM
auldtam
08-21-2008 10:19 PM
Quick Reply: Leaking Power Steering Rack
