lower front engine mount bracket replacement
Old 05-28-2013, 11:03 AM
wrldky's Avatar
Default lower front engine mount bracket replacement
2001 Volvo V70 XC
My lower front engine mount bracket is cracked. The bracket that holds the mount not the hydraulic mount itself. This is the mount that is directly in the center of the car and underneath. Does anyone know how hard this is to replace? Can anyone tell me how to do it?
Any help is appreciated.
Old 05-28-2013, 01:41 PM
ES6T's Avatar
The torque rod?
Old 05-29-2013, 08:14 AM
wrldky's Avatar
No it is the "front lower engine mount bracket". I believe it is called the "engine mounting" Volvo part # 8649262.
Old 05-29-2013, 08:41 AM
ES6T's Avatar
Oh okay. Support the engine from below and unbolt it. You'll have to remove the air hose going to the throttle.
Old 05-29-2013, 01:46 PM
wrldky's Avatar
ES6T,
Thank you. How many bolts are holding it on? Do I have to remove the fan?
Old 06-02-2013, 11:58 AM
ES6T's Avatar
Three hold it to the block. You might have to remove the starter motor to make it easier. The fan would also give a bit more room. It might also help to unbolt the mount from the subframe and remove the mount and bracket together.
Old 06-03-2013, 07:45 AM
wrldky's Avatar
Just in case this comes up in the future it is not hard to do at all. It is easier to remove the fan but also possible to do without removing it. Turns out the reason two of the bolts were missing was because someone had previously snapped the heads off trying to remove them. I tried my best and could not ectract the bolts so I had to have it towed away. I hate to give up but yo have to work blind and it was just too much.
froberts37
12-13-2013 04:24 PM
robinsonj
04-27-2013 01:38 PM
gentlejax2
09-05-2012 09:08 AM
wildboar
03-25-2012 06:14 AM
537playing
08-08-2010 08:53 PM
Quick Reply: lower front engine mount bracket replacement
