Battery Change = No climate control, stereo buttons not working
Old 07-30-2015, 07:59 AM
langdot's Avatar
Default Battery Change = No climate control, stereo buttons not working
Hey there... changed the battery in Volvo XC70 (2009) yesterday and immediately the fan/climate control and any buttons controlling the radio/stereo stopped working.
It's as if everything within the area encircled in red (see attached) has stopped functioning.
Anyone have any suggestions? Much appreciated!
Attached Thumbnails Battery Change = No climate control, stereo buttons not working-volvo.png
Old 07-30-2015, 08:41 AM
Welcome to the forum langdot
Have you checked the positive battery terminal to make sure all the wires are tight ??
Checked the fuse ??
Old 08-05-2015, 02:27 PM
langdot's Avatar
Checked the fuse ??
Thanks Kiss4aFrog.
I checked the following fuses:
Engine Compartment:
17 - central eelctrical module (20a)
18 - Acc Control module (5a)
32 - Compressor A/C (15a)
Glovebox Compartment:
18 - Information display (5a)
Cargo Area (Module D):
5 - Audio Amplifier (25a)
6 - Audio System (15a)
All were still fine. The only fuse I did not check and was curious about is in the Engine Compartment, Fuse 11 - Climate System Blower (40a). The manual reads that Fuses 1-15 are relays and should only be removed or replaced by a trained Volvo service Tech. Think this is worth me messing around with or am I entering a world of pain? I really don't think the climate system "blower" is the issue, as it seems to be an electrical malfunction to that whole interior panel (including stereo buttons...)
Outside of fuses, any other suggestions? Do you think I may have failed to check a critical fuse?
Old 09-28-2016, 09:48 PM
Phat's Avatar
Default Make sure the Battery have been disconnect/ reconnected with the right procedure
Here may explain your problem.
Try it:
http://www.freewebs.com/howardsvolvos/miscissues.htm
Missy1001
03-09-2021 12:04 PM
pagragg@pacbell.net
2001-2013 model year XC70
11-20-2012 02:37 PM
rowmike
07-11-2011 12:50 AM
nokinevoli
09-11-2009 12:39 AM
bishops60
12-25-2007 04:55 PM
Quick Reply: Battery Change = No climate control, stereo buttons not working
