hot, then cold, then hot, then cold HELP!
Old 10-19-2016, 07:52 PM
LNZ06XC70's Avatar
Default hot, then cold, then hot, then cold HELP!
Hi!, My SIL has a 2006 XC70 47000 miles. The car sat in a garage for 5 or so years and last year she started driving it again. all last winter her heat would blow hot then blow cold. My husband says it's not the heater core. He also checked the radiator, not that either. He changed the thermostat but it's still doing it. It's about to get cold again here in Chicago & we'd like to get this fixed. Anyone know or have an idea where he should look next?
Old 10-20-2016, 08:20 PM
There are motorized blend doors controlled by the climate control computer to set the airflow through the heater core, AC evaporator or both. Any blinking lights on the AC or REC buttons? Could be one of the door motors, the computer or a temp sensor. There may be fault codes stored in the computer but you may need a Volvo shop to scan as not all tools will read the the climate control fault codes.
Old 05-17-2021, 04:35 PM
Logan Anderson's Avatar
how do I delete a reply?
Last edited by Logan Anderson; 05-17-2021 at 04:37 PM. Reason: Wrong thread my bad
Old 05-18-2021, 11:43 AM
Do you see an edit button on your own posts? See if that allows you to delete the post. Otherwise moderators can delete for you
Old 06-10-2021, 09:17 PM
xc702011's Avatar
Default Same problem
We have a similar problem except it happens with the heater and the A/C, so the whole CCM. For about the first 15-20 minutes the temperature gauges work but then the CCM blows cold thereafter even if you turn the temperature up. We have to turn it up to Hi before any heat comes out. I borrowed a code reader from Advance Auto and looked the code up online and got this:
Volvo DTC CCM-B105A71
Make:
Volvo
Code:
CCM-B105A71
Definition:
Cabin Temperature Sensor Fan. Mechanical Failures. Actuator Stuck
v checks the status of the fan and temperature sensor in the passenger compartment. In order that the passenger compartment temperature sensor shall not be affected by surrounding electronics, a fan blows air from the passenger compartment at the sensor. The diagnostic trouble code (DTC) is stored if the control module detects that: The fan blades do not move. The control module's test for the diagnostic trouble code (DTC) starts in the event of: Ignition switch position I and II.
Cause:
  • Blower fan for the passenger compartment temperature sensor is blocked.
  • The fan is not working.
I need to know how to find the actuator and what to look for if it is stuck. I thought I might check the sensor on the CCM separately to see if that is dusty. Anyone have any suggestions?
jangrosicki
11-08-2016 08:13 AM
LNZ06XC70
10-26-2016 01:26 PM
artbar92706
09-13-2012 07:56 AM
PGall523
05-18-2009 07:22 PM
micah360
05-28-2008 04:14 PM
Quick Reply: hot, then cold, then hot, then cold HELP!
