P0571 and Brake failure - stop safely
I bought my 2004 XC70 with inoperative info lighting. After I changed the lighting switch assembly, the "Brake failure stop safely" warning became visible. The check-engine and ABS lights were not on but the P0571 code for the brake pedal sensor was pending. Other faults include an odometer that doesn't move very often, a trip odometer that only displays dashes, inoperative cruise control, non-functioning ABS (of course) and failed all-wheel drive.
I installed a spare brake-position sensor in the master cylinder to rule it out; nothing changed. Either both were good or both were bad, so I didn't learn anything. The service records indicate that the brake module was replaced three years ago but the multiple issues do indeed suggest a defective brake module.
Unfortunately, I don't have a scanner that displays the manufacturer-specific codes that I desperately need. (That's why I asked for opinions about the Autophix ES610 scanner.) Until I have a capable scanner, I'm dead in the water, but I'll update as this story unfolds because the symptoms are very common.
Just for the sake of trying out my new iCarsoft i906, I scanned all of the modules and, to my surprise, there were no codes stored in the brake control module. The only indication of a brake system issue was the P0571 (OBD2) and in the engine control module: ECM 9400 ("brake switch A circuit"). When I previously changed the brake position sensor, I didn't have the capability of clearing the code in the ECM. Not that I have that capability, the car cannot be driven because it is a bloody mess. It would be good to know whether I have a good spare BCM or not but making the car driveable again would be a lot of work.
ecf
2001-2013 model year V70
02-17-2018 12:45 PM
PapaBruce
2001-2013 model year XC70
09-30-2014 06:43 AM
Pos392@yahoo.com
07-05-2012 10:26 AM
