140 series
Old 04-12-2008, 11:34 AM
Mike B's Avatar
Default 140 series
I have a lot of old 140 series bits and pieces...is anyone still building or re-building these 'true' Volvos? Does anyone need the pieces?
Old 04-22-2008, 11:43 AM
SC Surfer's Avatar
Default RE: 140 series
There is one part I can't find anywhere--it's for an automatic and it's the small plastic bushing that goes right behind that big nut on the shift lever.It looksabout the size of a golf ball--maybe a bit smaller.When it wears out the shift lever makes contact with the horn while shifting into reverse, and goes off. Every time I find one at a salvage yard it crumbles the minute I remove it.
Thanks
Old 05-30-2008, 03:20 PM
We are resurrecting a 1973 142! In the process of removing the wheels for brake hose replacement, the nut for the hubcap bolt broke free of the mud-metal cap that holds it in place....Need new cap! Do you have one? Also, what is the sequence for bleeding the brakes????May need other parts too. Once one begins fiddling with things they tend to need replacing!
Thanks
Old 07-27-2008, 04:49 PM
brake bleeding...[/align][/align]Left rear[/align]Left front top chamber[/align]Right front top chamber[/align]Right rear[/align]Right front lower chambers (outer bleeder valve, then inner)[/align]Left front lower chambers (outer bleeder valve, then inner)[/align][/align][/align]
Old 12-27-2008, 05:36 AM
What kind of stuff do you have?
Dynodave
Old 02-21-2017, 03:59 PM
Bullwinkle's Avatar
Default Dashboard?
I have a 1968 Volvo 142 that's in serious need of a dashboard, voltage reg, generator,and weather-stripping. I can't find neither anywhere besides the voltage reg and some altenator coversions. Nor can I find floor pans and I really need front and rear. Have any lenses for a 68 such as tail lights?
Also know where I can find a good wiring diagram?
Old 04-03-2017, 02:31 PM
Shelbyk's Avatar
I'm looking for a title or vin plates off a 72 142E, if possible. I'm having a hard time titling mine due to some salvage yard messing up paperwork. It's being recognized as "crushed" when it is whole, and unharmed.
I'm looking to replace the pieces with the vin on it, and Wisconsin will re-inspect and issue a new title for the new vin if I can manage to find all the bits and pieces required.
Old 02-16-2018, 11:45 PM
Redliner's Avatar
I’m restoring a 69 142. Probably need a bunch of things.
Old 02-17-2018, 07:35 PM
TnBob's Avatar
Bullwinkle .. google is your friend ... https://www.ebay.com/itm/1968-1969-1...4383.l4275.c10
Old 02-17-2018, 07:36 PM
TnBob's Avatar
Mr Vintage Machine
West
12-12-2008 02:15 PM
Mr Vintage Machine
12-12-2008 02:10 PM
matt_white
11-28-2007 02:11 PM
redcarnut
09-05-2007 02:21 PM
redcarnut
01-25-2006 10:08 PM
Quick Reply: 140 series
