Volvo 460 (Lambda Signal)
Hello, it's me again.
In a a Volvo 460 after replace the oil and filter and the oil became over the high limit around 15% the green lambda signal appears. Maybe I used the car around 10 times before that siginal appears. Now when I am trying to turn on the car he turnīs off. I must try to turn on a few times and then press the pedal to heat the car and then itīs almost fine to run. This takes arround 5 minutes.
I think all this happen because the oil level is over the limit but can be other things.
What type you give me?
1 - Change the lambda sensor?
2 - With the stick level meter give out the oil by introducing and give up and clean? (I must do this 1 Million times I know)
3 - Change the oil again
4 - Other Suggestion.
Thank You any way.
Thank You any way.
Kargavibe
02-26-2017 10:53 AM
radja
04-30-2011 08:31 AM
