Volvo 460 Battery Full, When turn the key to position III theres no signal of start
Old 02-26-2017, 05:37 AM
Kargavibe's Avatar
Lightbulb Volvo 460 Battery Full, When turn the key to position III theres no signal of start
Hi there! I am new to the forum. Hello to everyone.
This is my first post here.
This is the second time that happens to me.
I use the car and park the car. Then I go to make what I need and then when I come back to the car I open the door, put the key on ignition. I Rotate the key to position I then, to position II, and when i turn to position III thereīs no signal of "auxiliary motor". NO sound. In this steps some ligths in the panel turn ON some turn OFF.
I think that maybe Volvo have some locking system so that makes no possibility of turning the car On for some reason.
I tried to turn on with very possibilities. With driver door open. With locked doors. With belt locked/unlocked, with radio plugged or unplugged.
The Battery is full. The "auxiliary/motion" motor is fine. The key appears to be in good shape. The ignition appears to be in good shape too.
There is some lights here?
Thank you for reading this text.
Old 02-26-2017, 10:53 AM
Kargavibe's Avatar
Solved.
How:
1-Unlock the car by key.
2-Open Capot
3-Put the Key in Ignition
4-"Turn Garage Ligth"
5-Fill the "regrigerator" liquide (Maybe this was the key)
6-Radio front panel already out
7-Conductor door keeps open, capot keeps open, turn the key to III to turn on the car after "Abs", "Srs" and "Delta" light's turn off.
8-Bingo
Hope help you with same situations. If it help's happy to ear from you.
davidx1994
01-01-2020 03:15 AM
dbak29
07-19-2018 10:03 AM
urdrwho
10-15-2015 03:38 PM
hehnhuus
1998-2000 model year V70
10-22-2014 03:57 PM
stu_cole
09-21-2007 06:22 PM
Quick Reply: Volvo 460 Battery Full, When turn the key to position III theres no signal of start
