Volvo 460 (Lambda Signal) - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 03-09-2017, 09:15 AM
Default Volvo 460 (Lambda Signal)
Hello, it's me again.
In a a Volvo 460 after replace the oil and filter and the oil became over the high limit around 15% the green lambda signal appears. Maybe I used the car around 10 times before that siginal appears. Now when I am trying to turn on the car he turnīs off. I must try to turn on a few times and then press the pedal to heat the car and then itīs almost fine to run. This takes arround 5 minutes.
I think all this happen because the oil level is over the limit but can be other things.
What type you give me?
1 - Change the lambda sensor?
2 - With the stick level meter give out the oil by introducing and give up and clean? (I must do this 1 Million times I know)
3 - Change the oil again
4 - Other Suggestion.
Thank You any way.
Thread Thread Starter Forum Replies Last Post
Volvo 460 Battery Full, When turn the key to position III theres no signal of start Kargavibe All Other Volvo's 1 02-26-2017 10:53 AM
A Volvo 460 Volvo 400 All Other Volvo's 0 06-01-2012 09:38 AM
Please anyone help me: Volvo 460 not working central lockig system radja All Other Volvo's 0 04-30-2011 08:31 AM
460 Volvo Timing Belt or Chain?... chris_knows All Other Volvo's 4 09-09-2006 09:49 PM
Volvo 460 lower springs needed AK Suspension 2 08-22-2006 02:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
