BluePower BLP-890 gps causing climate control issues? - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 10-20-2009, 10:37 AM
Question BluePower BLP-890 gps causing climate control issues?
Hello all, I just bought the BluePower BLP-890 and I just finished installing it, but now my rear defrost, and heated seats buttons on the actual climate control panel don't work. The heated seats are now permanetly on unless I remove the fuse (because the buttons don't work to turn them off, they're not even lit up, nor function.) Also when I press the rear defrost button (even though it's not functioning, or lit up, I hear a clicking in the back when I press the rear defrost button.)I wasn't sure why this was happening, so I checked all of the fuses and they were all fine. I even went out and looked for a new climate control panel, found one and spent nearly a $100 on it, and it did not fix the problem.I'm not sure what to do, has anyone heard of this problem, is it even the BluePower HU? Please, if anyone can help, it is already in the 40's in Chicago, and the rear defrost does not currently work. Thanks so much in advance,BrianP.S. I don't really want to go back to the stock unit.
Old 10-20-2009, 04:06 PM
Let's start by naming year and model of your vehicle. Describe in detail your installation since we are under the impression all your problems occurred after the install.
Old 11-02-2009, 07:54 PM
imhereftw's Avatar
I'm assuming you did the install your self?
Old 11-03-2009, 07:36 AM
Quote:
2001 S60 -I did the install myself, to start off with.I took out the climate control, then the stock HU.I then did the install of the BluePower unit, I also hooked up their ipod cable, and their gps antenna. I am pretty sure I hooked up everything correctly! I then hooked the climate control back up, started my car, to test it out, and that's when I noticed that the lights were no longer on the rear defrost, or the heated seats. When I push the heated seats buttons, I get nothing, no lights or anything. The heated seats are permanently on, unless the fuses are removed.The rear defrost button when pushed makes a clicking sound in the back seat, but it does not come on or stay on automatically like the heated seats. I have also noticed one more problem, the mirrors used to be heated, and I think they no longer work from this climate control issue?If you need any other info, please reply.Thanks,Brian
Old 11-03-2009, 08:30 AM
imhereftw's Avatar
Try calling blue power, they may be able to help assuming that they have English speaking customer support :P
Old 11-03-2009, 09:32 AM
Quote:
I contacted them and they said "they have never heard of this problem."
Old 11-03-2009, 09:34 AM
Forgot one thing... There was no need for any wiring harness either. These HU are made specifically For Volvo.
Old 11-04-2009, 11:56 AM
Quote:
Did you disconnect the battery before you removed climate control?
Old 11-05-2009, 07:55 AM
The first time, I did.... The second time, I didn't.
Old 11-06-2009, 11:21 AM
Get a code reader and see if any codes pop up. Next if necessary reinstall factory radio. Need to see if the problem is related to the install, or just a coincidence. Keep us posted.
Old 04-09-2010, 09:59 AM
Ok, still having this problem! I took my car to the Volvo dealership earlier this week and they did a diagnostics on my car. They found nothing, no codes that had to do with it. I have also noticed that even though the heat seaters and rear defrost lighted controls on the panel don't light up when pushed, if i push them the heated seats and rear defrost do work, the controls on the panel just don't light up!? I also have the same problem with another climate control panel I bought, thinking it would fix my light issues on those controls. But I thought wrong. What could be the problem here? The controls work on both panels I have tried, but they don't light up on either panel? I don't get it. Do you think the after market HU could be missing a certain conection to light that part up? The HU doesn't even hook up to the climate control panel, it just plugs into the stock Volvo harness, so I don't get why it is causeing this problem. Fuses are fine, could it be a relay? or is there something under the hood I could check?Any help would be greatly appreciated. Brian
Old 04-18-2010, 05:26 AM
Art - This is excellent news. I have been exploring aftermarket options and none as nice as this. Recognizing that IPD will sell it, who would you reccommend in Edmonton/ AB to install such a unit. Not withstanding the obvious answer being me. I have seen the work you have done on your own car, i don't trust myself with electronics.
____________________________________________
Woodworking Plans
Steak London
Old 04-18-2010, 10:34 PM
Banned
_________________________________________________
increase stock volume
employee benefit management
Old 05-18-2010, 05:41 AM
Banned
Breast Augmentation Breast Enlargement
Thread Thread Starter Forum Replies Last Post
New radio causing headlight issues... jcedor Volvo 240, 740 & 940 1 07-08-2015 11:10 AM
Camber issues causing car not able to drive in rain or snow mhop3420 2001-2013 model year XC70 2 01-06-2015 06:25 PM
890 bhp bubba240 Volvo 240, 740 & 940 2 01-16-2010 11:57 PM
No Climate Control/Cruise Control??? jfikentscher Volvo 850 4 05-31-2006 09:58 PM
1993 850glt climate control issues vict8r Volvo 850 1 10-26-2005 01:04 AM
Tags
890, blp, blp890, blue, bluepower, climate, control, gps, ipd, power, s40, s80, trademark, volv0, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
