Central MT, WY, CO, ND, SD, NE, KS
Knocking
Old 04-27-2014, 01:00 PM
jumpinjackflash's Avatar
Question Knocking
I have knocking sound coming from the front wheel area. This increases with speed, as though something is catching on the wheel. Just had burst tyre replaced after small impact. Any ideas? Drives fine otherwise and only makes the noise when going straight.
Old 04-27-2014, 06:18 PM
difflock54's Avatar
Check the fixing clips on the plastic sumpguard panel or the wheel arch panels in front of the wheel.
Might be loose and flapping about with airflow movement under the car?
Old 07-20-2018, 10:17 AM
eflexter's Avatar
It's fairly common to break the sway bar linkage ball joint in an impact. The unconnected link may be rubbing against the wheel.
Corban L Russell
03-05-2015 11:36 AM
Thederrick
04-18-2014 11:30 AM
AVIATOR83
07-16-2009 08:19 PM
sheriffjohn
07-31-2008 09:28 PM
rejeep
11-20-2006 01:11 AM
Quick Reply: Knocking
