Detailing Discuss detailing your ride inside and out here.
Best Protection For Your Rims - Nano Ceramic Glass Technology
Old 01-03-2014, 09:22 AM
PinnacleWax's Avatar
Former Sponsor
Default Best Protection For Your Rims - Nano Ceramic Glass Technology
Pinnacle Black Label Diamond Wheel Coating - 18 MONTH PROTECTION
Pinnacle Black Label Diamond Wheel Coating blankets your wheels in a rock-hard barrier of protection that is impenetrable by ferrous brake-dust particles, road salt, tar or oil. Designed with brake-dust laden sports cars in mind, Diamond Wheel Coating and the layer of protection it creates makes laborious wheel cleaning a thing of the past. The super slick surface virtually eliminates brake-dust build up. Spray and wipe application lasts up to 18 months!
Let’s face it: wheel cleaning is a chore that nobody enjoys. It’s often messy and it takes considerably longer than it should. Pinnacle knows this, which is why they developed a specially designed wheel coating as part of their Black Label line of products – Diamond Wheel Coating.
Black Label Diamond Wheel Coating is a nano-glass ceramic coating that was designed specifically for application on wheels. Formulated to withstand the extreme temperatures that wheels are exposed to, Diamond Wheel Coating shields your wheels against the damaging effects of ferrous (iron containing) brake-dust particles. A single 4 ounce bottle is enough to coat up to 100 wheels!
Wheels that are coated with Black Label Diamond Wheel Coating will be easier to clean and maintain. Regular wheel cleaning will only require soap and water, even on brake-dust laden German sports sedans. Diamond Wheel Coating creates such a slick barrier of protection that most dirt and grime will be removed when driving through the rain. A strong jet of water from the hose will also knock off most of the built up brake dust, minimizing the amount of scrubbing required.
Black Label Diamond Wheel Coating is safe and effective to use on all types of wheels. Use Diamond Wheel Coating on painted, clear coated, polished, anodized, chrome, and bare aluminum finishes. Even use the coating on your brake calipers. Spray and wipe application only takes minutes to apply, and the glossy layer of protection lasts up to 18 months.
Black Label Diamond Wheel Coating should only be applied to wheels that have first been polished with Black Label Surface Cleansing Polish. This step is crucial as it removes contaminants, oils, and fillers that would otherwise prevent the coating from bonding. Once that is completed, application of Diamond Wheel Coating is as simple as spraying on and evenly distributing with a foam applicator.
Directions:
1. Ensure surface is cool to the touch and out of direct sunlight.
2. Thoroughly clean each wheel first using Pinnacle Clear Coat Safe Wheel Cleaner.
3. Polish wheels with Black Label Surface Cleansing Polish.
4. Spray Diamond Wheel Coating directly onto a Gold Wax Finger Pocket and evenly distribute over the wheel.
5. Work the coating into the surface until it disappears.
6. Lightly buff with a clean, soft, lint-free microfiber towel.
Check out the Black Label Diamond Coating Application Guide for more thorough instructions on how to apply the coating.
GET YOUR WHEEL COATING AT PINNACLEWAX.COM
. Don't forget to check out the Paint, Glass, and Surface Coatings
Save 20% OFF and Free Shipping Over $50 right now also - Use Coupon Code PIN2014
carid
06-18-2015 08:08 AM
PinnacleWax
01-07-2014 04:52 PM
Willybee71
12-03-2012 05:26 PM
Tacodog
05-15-2008 09:42 AM
J Thomp
01-19-2005 04:23 PM
Quick Reply: Best Protection For Your Rims - Nano Ceramic Glass Technology
