Engine Wiring Harness Help
will the engine wiring harness from a 2005 S40 fit a 2007 S40?
Will all the parts from a 2005 S40 fit a 2007 S40?
I am new to the forum and new to Volvos as well. I have a lot of experience with cars, but mostly first generation Camaros (building two currently).
I am looking to purchase a 2007 S40 that currently will not run, the motor will turn over, but it will not crank.
The motor in the 2007 was installed by the second owner because the timing belt broke on the first owner. After the motor was installed the Used motor (pulled from a 2006 S70) would not run and the owner was told the car needed a new computer so the owner did not want to invest the money and sold the car to the current owner.
The current owner has had the vehicle in the shop and his mechanic told him he needs a new wiring harness. Now the current owner of the 07 does not want to invest the money to buy a new wiring harness.
A friend gave me a 2005 S40 with 80K miles because the timing belt broke and he did not want to repair it.
Is it possible to use the 2005 as a donor car for the 2007?
Does anyone have any tips on how to verify the wiring harness is bad?
Any help would be greatly appreciated.
Here are the pic s from the 07, I may get it for a parts car for my 05.
If I can determine if the head off of it will work on mine.
He's dropped the price considerably (to the point I can't buy a head as cheap as his entire car).
AnEskimo
09-17-2014 01:00 PM
