Ethanol and old Bosch fuel injection systems
Old 01-30-2015, 07:15 PM
ecolo's Avatar
Default Ethanol and old Bosch fuel injection systems
Keeping my 1981 245DL on the road was proving difficult. Its "Constant Pressure System" was failing despite all my efforts. Thanks to an earlier post on this forum, detailing replacing fuel injection with carburetor, I obtained two marine carburetor manifolds--one for downdraft, the other for sidedraft carburetors, I tried first a Holley downdraft carb which failed due to ethanol attacking its zinc body--according to carburetor forums.
Finally I found a Carter 684S cast iron body carburetor (downdraft) which so far works ok, far better than the replaced fuel injection system. My impression is that the original system couldn't handle ethanol fuel, creating problems regulating its internal pressures, resulting in erratic operation.
The biggest problem now is to remove all the wiring, most of which I replaced before, associated with the old FI system. Amazing how accessible the engine is now with the FI system removed. My impression is that cars over 25 years old, in many states, can be legally converted as I have done.
Manual choke and throttle hookup were simple. The Delco aftermarket fuel pump pulled fuel through both original disconnected fuel pumps and the stock FI fuel filter without problems, producing 6 lbs. at the carburetor.
Attached Thumbnails Ethanol and old Bosch fuel injection systems-81-volvo-49-chevrolet-carter-carburetor-installed.jpg
Old 01-31-2015, 08:32 AM
fochs's Avatar
Do you have a link to that thread? Pics of yours?
Old 02-01-2015, 01:42 AM
which FI system did you have?
i've got several very high mileage volvo LH systems that have been running on E10 california crap for years now without any fuel system problems. I'll take the 10% ethanol stuff over the MTBE junk they fed us before.
Old 01-01-2022, 11:46 AM
Smithsonite's Avatar
Last edited by Smithsonite; 01-01-2022 at 11:47 AM. Reason: Somehow replied to wrong thread ...
tumbleweed
07-27-2023 07:39 AM
inilegna
09-25-2013 03:27 PM
volvovera
02-19-2011 07:55 PM
ajservices
03-18-2010 01:19 PM
DVTO
07-09-2009 02:58 PM
Quick Reply: Ethanol and old Bosch fuel injection systems
