2000 S70 check engine light
I just replace the radiator in my 2000 S70. Drove it home 25 miles or so & everything was fine. Drove it the next day for a bit still fine. All at once the check engine light came on. Then when I pushed the gas pedal the car will shake & the check engine light will flash.once I get up to speed the check engine light will stay solid but car runs smooth until I push the gas pedal again. I replaced the mass air flow sensor, air filter, spark plugs, use injector cleaner & a full tank of premium gas but no change. Thanks for any help!!
ErnstlS90
10-23-2008 08:37 AM
