Air conditioner blowing hot air ..
Old 06-18-2014, 02:28 PM
HarryO's Avatar
Default Air conditioner blowing hot air ..
2008 S 60 AC blowing hot air ... Does it need
Refrigerant ? New to Volvo .. Do you add
Like other cars ?
Old 06-13-2015, 04:50 PM
MSGTUSMC's Avatar
Default A/C
Is the clutch engaging? Do not add refrigerant until high and low pressure lines are checked. A/C r.elay may be the problem. JMHO
DLWest (07-15-2023)
Old 07-15-2023, 03:47 PM
DLWest's Avatar
Default AC Fails above 75 degrees
I’m the 3rd owner of a great 2010 XC90, w/low mileage. In 2022, I noticed the Control Module AUTO button sticks off & on. Most of the time, the AC won’t blow cold air if it’s above 75 degrees. Mixed opinions from my 2 Volvo mechanics: replace the AC compressor or control module. Just changed the Serpentine belt & cabin filter. Comments & suggestions are much needed as I cannot replace both! 😊.
Old 07-15-2023, 03:58 PM
What engine?
The 3.2 compressors have a variable displacement valve that can go bad and cause your symptoms. (ac not cold when it is supposed to be, that is with power to the ac clutch)
tinyketchupbottle
06-07-2021 04:32 PM
Jeremiah Green
01-21-2021 09:31 PM
Matt Fairbrother
10-07-2020 01:16 PM
Sherry007
04-05-2015 09:21 AM
mclaing
07-25-2014 01:34 PM
Quick Reply: Air conditioner blowing hot air ..
