Battery dead...How do I open the trunk
Old 01-24-2008, 12:14 PM
JMorse's Avatar
Default Battery dead...How do I open the trunk
I have a 2002 S60 AWD with a dead battery...I think. We open the trunk with our remote but all is dead and I can't get the lid open. Does anyone no how to get access?
Old 01-24-2008, 01:53 PM
billofdurham's Avatar
Default RE: Battery dead...How do I open the trunk
From the Owner's Manual:
Opening the trunk from the inside (U.S. models only)
The S60 is equipped with a florescent handle on the inside of the trunk lid, which can be used in an emergency situation to open the trunk from the inside. Pull the handle down to release the trunk lid.
This handle is not intended to be used to anchor the trunk lid when long loads are being transported.
Old 01-24-2008, 06:11 PM
There is also a black cover to the right of the Handle remove the black cover and use the key.
Old 01-19-2017, 04:13 PM
Angelsfly's Avatar
Default Easy Fix
Look where you reach under to unlatch the trunk. On one side of the long button you will see a roundish rubber thing. Take that rubber thing off and the keyhole is under it. Hope this helps
Mike Leger (10-31-2020)
Old 01-20-2017, 07:02 PM
donf's Avatar
Isn't that primarily for if you are locked in your own trunk and want to get out?
To get in the trunk he would have to fold the seats down and crawl through, but the latch to fold the seat down is in the trunk over the tail lights, right?
Old 01-21-2017, 01:20 AM
Angelsfly's Avatar
Default reply
I am am not referring to the emergency release latch inside the trunk. The thing I am talking about is on the outside of the trunk. It is located near where you put your hand to open the trunk normally if the battery was not dead. Normally you would push the trunk button on the remote and the reach under to release the catch to open the trunk. The thing that I am referring to is to the side of the catch release button. It's sort of roundish and is rubber. It's not very big. Just simply remove this rubber cover and you will expose the keyhole for the trunk. All you need to do now is insert the key into the keyhole and turn. The trunk can then be opened. There is no reason to try to get into the trunk to pull the emergency release. Especially since the only way to fold down the back seats are release pulleys inside the trunk. Bad design idea. I hope this explains in detail what I was trying to explain earlier.
Old 01-21-2017, 11:22 AM
donf's Avatar
Wasn't qouting you Angels, you did indeed give a correct answer.
I thought it was clear I was referring to the reply of billofdurham.
BTW - The glow in the dark handle really is for people who get locked in their trunk! And it became mandatory in 2002.
Here, read the reason why: There's an Escape Release in Car Trunks Due to One Woman Kidnapped and Locked in Hers | Atlas Obscura
And more: https://www.cars.com/articles/2012/0...r-saves-lives/
Would have saved some anxiety when I was in high school and we would sneak into drive-in theaters (look it up) in the trunk so that only one person -the driver - would pay. There was always the fear that the driver might be a smart-*** and leave us in there until after the movie.
Old 04-25-2020, 03:19 AM
dericksonpe's Avatar
I diconnected the battery and then my son closed the trunk. We do not have access to the trunk now. Please let us know how we can still provide enough power without the battery to the car in order to open the trunk. Thank you!
Old 04-25-2020, 10:46 AM
do you still have access to the cabin so you can open the hood? there's jumper terminals under the hood.
Old 04-25-2020, 01:49 PM
ssicarman's Avatar
You don't provide the year and model but.....mechanical key lock in the trunk?
Old 04-25-2020, 01:56 PM
good point - some cars have the emergency key slid into the fob.
Old 10-10-2020, 12:57 PM
Nathaniel-tb's Avatar
Default Help me please!!!
I opened the little compartment where the key hole is for the trunk and twisted with the masterkey... Nothing happens I twisted for a minute and nothing opened... Is there any way to solve this/get in the trunk
Old 01-27-2021, 02:04 PM
Stewart-18's Avatar
Twist it counter clockwise to open. The opposite to lock.
Old 12-26-2022, 09:43 AM
imrnet0613's Avatar
Were you able to open the trunk? I have a 2020 S60 and can’t find the key hole either. Is there one for my model? If so, do I have to remove the rubber hand latch first? So frustrating. TY
2006volvo2
12-19-2015 11:06 PM
Vincef
03-18-2009 08:42 PM
glt93
02-09-2008 12:41 AM
sagi122
02-16-2006 09:26 AM
midtown44
11-26-2005 09:45 AM
Quick Reply: Battery dead...How do I open the trunk
