chiming when key removed
Old 04-23-2015, 10:38 AM
djohn111's Avatar
Default chiming when key removed
When I turn key to removal position there is a slight sticking as I go into the final removal position. When I remove the key and open the door, it chimes.
What can I do to fix this. I cannot lock the doors with my remote because of this.
Old 05-24-2015, 08:34 PM
Left Lane Brain's Avatar
Assuming its a sticking switch, you could try to use some dry graphite lube in the lock cylinder/ignition switch. Replacement of the ignition switch should definitely do the trick, if thats in the cards.
After you pull the key out and open the door, have you tried tapping on the ignition switch? If you do, can you get it to stop? This should tell you if its a sticking switch or a wiring issue somewhere in the ignition. Fuses all good?
eastpt
08-01-2011 07:15 AM
chelle21578
09-12-2010 03:17 PM
erics84
05-28-2009 02:22 PM
Floaterdave
01-26-2009 10:56 AM
Volgrrr
07-25-2007 06:26 AM
Quick Reply: chiming when key removed
