DIM programming
Old 06-29-2016, 12:57 PM
onycyuk's Avatar
Exclamation DIM programming
Hy to all, i need a little help with my volvo V70 2.4 d5 "02 , if just boght this car at low price because was without Instrument Cluster, if got one from another car but i need to coding or programming it,because is not working not even get on the lights, is someone that knows if the cinese Dice , Super dice+, it works to do such thing without go at the delears. Tanks for your help.
Old 06-30-2016, 12:42 PM
doublebug's Avatar
What is MY of the car. (10th symbol of VIN code)
What is part number of the DIM in the VIDA->Diagnostics->Network?
sturmtiger (05-14-2022)
Old 07-01-2016, 02:14 AM
onycyuk's Avatar
The MY is 2 and the part number of dim ai don,t now because i not have Vida diagnosis., i under if with vida dice clone can i make the programmin or whatever is called the process. tanks in advance
Old 07-01-2016, 08:22 AM
onycyuk's Avatar
ok i found it the answer of 2 question DIM reload 1.00 SW 9438293
Old 07-02-2016, 04:08 AM
doublebug's Avatar
That is not right. That number is for order software.
And software can be loaded only if DIMs part number is compatible with the car.
That is why I asked for it.
And right DICE clone can be used for programming. That is the one based on the same microcontroler as original.
Old 07-02-2016, 05:12 AM
onycyuk's Avatar
Yes you right so i will take out the dim and i will look for the code. Is something with 92.....i will tell you the number, i have two instrumental cluster...
One is VCC P.No 9472452
S.No 14615
YZK P.No 69294--160
Ok now the second
Vcc 9499671
serial n. 14615
Yzk 69294--580t
I hope that ar good... tanks
Old 07-02-2016, 03:21 PM
doublebug's Avatar
Both DIMs does not fit your car.
First is for 1999-2000 MY
Second is 2000-2001 MY
They cannot be programmed for your car.
Old 07-02-2016, 03:58 PM
onycyuk's Avatar
how about this one i thing that i can do it 30682277 8602885 69594-220T 1639329
Old 07-03-2016, 03:58 AM
doublebug's Avatar
That can be programmed but you need to make adapter because socket is different.
That is 2005 MY DIM.
Old 07-26-2016, 05:58 AM
onycyuk's Avatar
If i have the right panel,i must download software in it or just programing normal ...in vida without downloading software...? Tanks
i buy it a clone dice +....i opened a tread...tanks for you help very much and forgive me for my gramatical error.....and if i do something wrong. tanks for you patience again.
Old 07-26-2016, 08:22 AM
onycyuk's Avatar
Teach me please how u can know if the instrument cluster is compatible with my car (MY) just look the s.n of instrument cluster, that way i will search one right for my car. tanks very much
Old 07-26-2016, 08:23 AM
onycyuk's Avatar
and when i will find i must download the reload software? or just plug in and work. tanks
Old 07-27-2016, 06:00 AM
doublebug's Avatar
You can reprogram DIM using official way (paid subscription for VIDA + additional fee for software itself) only if DIM is officially compatible to your car. In your case that is only for DIM from 2004 MY car.
DIMs from 2005 and later cannot be programmed to your car using VIDA.
Pirate version of VIDA does not have ability to load software.
Old 07-27-2016, 03:22 PM
onycyuk's Avatar
First of all thank you for your response and I want to bother you with any questions if I can afford.
* How do I know that DIM is compatible with my car since he does not have the old Dim ... as I realize just checking VIN.
If you give me a link where I register and pay for vida, I tried but I do not go considering that I reside in Italy. I look only Canada, Portugal, USA.
****** Thank you very much for your help
Old 07-27-2016, 03:55 PM
doublebug's Avatar
DIM from the same model year car will work without programming.
Old 07-27-2016, 08:34 PM
Smith Volvo's Avatar
Banned
this is correct - I did this on the mother-in-laws car. Only thing is that it will now display the mileage of the car that it came out of. The CEM will still have the correct mileage although.
gwp02035
10-25-2017 03:52 PM
bit_eimer
06-11-2017 10:09 PM
djerikd
10-27-2008 07:34 AM
spacemn2
03-14-2006 10:04 PM
sudvam
10-30-2003 12:56 AM
Quick Reply: DIM programming
