Exhaust on a 740 wagon
Old 10-25-2014, 08:58 PM
jayvolvo740's Avatar
Default Exhaust on a 740 wagon
Hi, I am hoping that someone can tell me if there is a specific reason for the "S" shaped tailpipe on my '92 740 wagon. I am replacing my muffler and tailpipe soon and wondering if I can use a straight tailpipe instead. Thanks
Old 10-25-2014, 09:05 PM
Default Spark plugs
Hi, I am replacing my spark plugs soon and I am wondering if I can use Autolite double platinum plugs in my '92 740 2.3L. This was suggested to me at my local parts store. Thanks.
Old 11-22-2014, 09:37 AM
Moved to the 740 section.
You can replace the muffler with straight pipe but it's going to drone quite a bit and be a bit irritating inside the vehicle at highway speeds.
Old 11-22-2014, 04:23 PM
no, don't use any sort of platinum or iridium or whatall modern plugs, they won't work well with the late 1980s early 90s electronic ignition systems in these cars.
Use copper plugs, like Bosch Super+, or NGK standard, or Volvo OE.
NGK BPR6ES or Bosch SuperPlus WR7DC
a set of 4 Volvo brand plugs is $12 or so online...
Old 11-22-2014, 04:26 PM
re; S pipe..
(mine)
I believe its A) so you don't bang your shins on it when you're loading the car and stand too close, and B) so if you back into something, it has more give, a straight pipe would more likely damage the muffler.
Old 11-22-2014, 09:15 PM
If you go with copper plugs just remember to check and or replace them more often.
Old 11-23-2014, 01:10 AM
Actually, the higher voltage of the old style ignition system will likely burn out the platinum plugs, which have a very thin electrode, faster than the copper ones.
the standard plugs are good for 60000 miles if you're cheap (I'd probably replace them at 30000).
Old 11-23-2014, 08:20 PM
Ok thanks for answering my question. I appreciate it.
andrewma
05-16-2018 01:47 PM
volvoQ's
09-26-2010 01:45 AM
turbowagon94850305
07-31-2010 10:48 PM
turbodude
05-20-2010 05:50 PM
Fluxmotoring
11-18-2008 02:53 PM
Quick Reply: Exhaust on a 740 wagon
