How to change thermostat and ECT on S60
Which setup do you have?
If it is turbo looks like it is this setup. http://www.fcpgroton.com/product-exe...category_id/88
If you have that one I believe you need to remove the power steering pump to swap it out.
If you have a Non turbo it should be the other setup with the 2 torxes screws which is alot easier. You will loose coolant when you remove it. Put a pan under the car.
depending on what yrs of your p2 is. there thermostat housing could be different. but if you have a non-turbo, chances are you have a early model w/the 2 torx screws on top. if you are doing it yourself, i advise you to take the top left plastic cover off before you take out the torx so you won't damage it. i did many of those thermostat and i never drain the coolant, you will have a little coolant leak out but u just top it up afterward. but do it when the car is cold and with coolant reservoir cap on so u won't loose too much coolant
rspi
06-28-2013 10:33 PM
2005, 25t, 60, change, check, code, ect, engine, replace, replacement, s60, thermosta, thermostat, thormestat, volvo
