Rear washer pump
RE: Rear washer pump
It's easy to fix, I just replaced mine on my 89 740 wagon. However, the Volvo part is about $80.00!!!
Check out
http://www.idpusa.com/
or
http://www.vlvworld.com/
for an after market/OEM replacement at a fraction of the cost.
Recommendation: Get a replacement gasket from the dealer. It's only a couple of bucks. When you install the motor, make sure you use a generous portion petroleum jelly around the gasket and the part of the motor that goes through the gasket. The gasket will have no hole in it. What you do is to make a pin hole in the middle of the gasket. Install the gasket into the bottle and then plunge hose on the bottom of the motor through the gasket as you install the motor. You should coat the hose on the motor with Vaseline first. It's easier to do this if you remove the washer bottle. This way you can check for leaks *before* the bottle is in the car where it is exceptionally difficult to see where the leak is coming from.
I replaced both front and rear motors as they had both gone bad. They work perfectly. No leaks. The secret is the petroleum jelly and the new gaskets.
Check out
or
I couldn't find the line leading tothe rear windshield. I did notice that I'm not getting water to the headlight wipers as well, just a little trickle before it actually gets to the headlight wiper. Maybe they're related.
Tailgate repair was not too bad. Hardest part was getting off the handle trim.
I believe I have 2 separate issuses here. No water to BOTH the rear window AND the headlight wipers. If I'm correct, I believe the headlight and the windshield share the same pump. (which shouldbe ok because I get water to the windshield).Which in turn means I have a clogged line going to the headlights wipers.
Now for therear window washer....I'm not hearing the pump. (which has it's own for the rear). Am I correct? 98 v70
darkdelta
11-06-2008 07:36 AM
