Stopped a bad transmission leak - S70
My S70 developed a slight transmission leak, which turned into a serious one after about a week. Not wanting to spend more money than the car was worth on repairs, I set out to try and find a cheap solution. You may benefit from what I did to stop it, or you may take serious issue with it, but either way, it worked!
At the peak of the problem it was using about a quart of fluid every three days. I never determined exactly which seal was leaking, because the fluid seemed to be coming from more than one.
I read about Blue Devil transmission seal, so I used about 8 ounces of a 16 ounce bottle. After about 24 hours, the leak had decreased by about half. By a few days later the leak had begun to increase again, so I added the other 8 ounces. I was also adding transmission fluid according to the owners manual which called for Dexron/Mercon. Again, the leak decreased slightly, but was still using about a quart of fluid every 6 days.
It was at this point that the transmission started going into limp-mode on a regular basis. It would start off in 2nd gear and shift very hard into reverse. Also, if you accelerated from a start, but then hit the brakes, the transmission wouldn't downshift and the engine would stall.
I then spoke to a Volvo technician and he told me that the owners manual is wrong and to never use Dexron/Mercon. He said the limp-mode was caused by a sudden viscosity change in the fluid. He recommended draining the transmission fluid and re-filling with genuine Volvo fluid, (which was quoted at $33 per quart), which would have cost me $231 in fluid alone.
I then read about Toyota T-IV fluid and how it is the same formula as genuine Volvo fluid, but only $8 a quart. After adding the first quart of Toyota fluid, the leak began to subside. After three quarts, the leak stopped altogether and it hasn't leaked a drop now in over a month.
I think that the Blue Devil slowly re-hydrated the seal and, had I used the correct fluid to re-fill the transmission, the leak would have then stopped over time anyway. But I can say that since I added the Toyota fluid, the S70 has shifted better than it ever has before.
CaptainVintage
07-20-2015 06:05 PM
jeffrisley
06-14-2015 01:48 PM
