Which tyres ?
Yes. You have a mechanical AWD system so it is very important that the tires are the same circumference. Same size tires do not always have the same circumference so it is important that this dimension is consistent. As the tires wear, they need to wear at the same rate so I would encourage you to get the same brand / size / speed rating etc. As for a tire brand suggestion, you would need to let us know whether you want bias towards longevity, grip etc. Are you in a situation where snow tires would be used and if so you could get a little better 'summer' tire for performance. Otherwise, you'll have to compromise on 'all weather' performance.
