VOLVO 940 Oil ,Synthetic Or Semi Synthetic?
Old 08-01-2011, 02:10 AM
BenHur's Avatar
Default VOLVO 940 Oil ,Synthetic Or Semi Synthetic?
Hi
I Have Volvo 940 2.3 Turbo - 1998
Synthetic Or Semi Synthetic Oil . What Is The Best ?
What Company Recommended ?, My Country Is a Very Hot Country .
Thank You .
Alon BenHur
Old 08-01-2011, 03:08 AM
Full synthetic is always better but understand that seals that are in poor condition may give if you have NOT been using synthetic oils (so I've heard). I switched to synthetic in my daughter's S70 and a few months later I had to replace all four cam seals and a block gasket.
As for the area temp, I don't think that matters much on the type of oil as much as the weight. I'm a little bothered by the fact that it's getting hard for me to find 10w-30 with the new oil types. I actually like to run 10w-40 in the summer and can NOT find that anywhere in my area with the newer oils. I have to run around town and find older oil stashes to purchase. Stores that turn their oils faster are stocking this 0w-30 and 5w-40 stuff and I'm not sure if that's good for my turbo motor or not.
Old 08-02-2011, 03:27 PM
swiftjustice44's Avatar
Haifa, Israel? Partner, that's a walk in the park. Come on down here to Texas if you want some hot weather! 31 centigrade for a high where you are...41 here...synthetic works great in turbo cars because it doesn't cook down to coke in the turbo oil passages the way traditional oil will. My personal experimentation has led me to believe that 10W-30 is best for turbos. N/A cars I run 20W-50.
Old 08-11-2011, 02:07 PM
ibanez958's Avatar
syn. is always better, volvo recommend castrol on their vehicle
Old 08-12-2011, 04:15 AM
BenHur's Avatar
10W40 Sys ?and Castrol ? But if I Will Take Semi Sys , Will Be Any Problem ?
Thank You
Old 08-12-2011, 08:39 AM
kelsdreamcar's Avatar
Synthetic is great! I use the semi synthetic due to the fact that it lubes the older seals better than newer synthetic oils. just as was stated in the earlier thread.
Old 09-08-2015, 09:29 PM
Pierro's Avatar
Default Dealer knows!
Usually, your dealer is supposed to know and can give you some advices. I think that if they build an engine, they know what goes in it!!better chat with a mechanic who works on Volvos for many years instead of a young mechanic who is learning on yours!! Volvos are great cars so they need great care. Take good care of it and it will last.
Thank You
Anthead
03-28-2012 10:46 PM
Arsenal6
04-26-2009 02:34 AM
Cleverboy
12-06-2007 10:24 PM
s80t6schcik
03-10-2007 02:18 PM
turbodog
06-07-2006 03:27 PM
Quick Reply: VOLVO 940 Oil ,Synthetic Or Semi Synthetic?
