Volvo s40 1 water comming from exhaust runs fine
Old 03-15-2017, 01:07 PM
Brian500's Avatar
Default Volvo s40 1 water comming from exhaust runs fine
I HAVE A 2001 1.8 VOLVO S40 1 I.8 i have had it serviced recently and the car runs good , i put it on the emission tester today and it was excellent but their is water coming out of exhaust, i cant see how its the cylinder head gasket because it runs good and smooth, the guy who done the test hasn't a clue. if its the head i shall have to sell it
Old 03-15-2017, 04:29 PM
If you are not losing coolant and the exhaust doesn't have a sweet smell then you're just looking at a cold exhaust system that's not warm enough to vaporize the water produced by the burning of the fuel.
Old 03-15-2017, 04:51 PM
Brian500's Avatar
Default volvo water from exhaust
thank you for your reply, if I take car on a long run then when its hot it shouldn't be dripping water out of the exhaust, is that correct,
Old 03-15-2017, 07:31 PM
firebirdparts's Avatar
That's kind of a generalization. There should be water in the exhaust, a lot of it. It is winter, at least assuming you're in the northern hemisphere. I wouldn't want to say that some of it won't come out as liquid. Even if it's all hot, it condenses into a fog quickly in really cold weather.
Old 03-16-2017, 11:42 AM
Brian500's Avatar
Default vovlvo losing water
thank you for your reply firebird, I took the car down the motorway this morning and gave it a good run, I filled the expansion tank with water when I got back the car stayed around50% on the thermostat gauge. but the expansion tank was half full the car seems to run ok , when I stopped I could see like steam coming from the exhaust I normally only run it around town doesn't get a lot of use
VolvoLover2011
03-23-2013 04:27 PM
rvinson2
07-27-2009 09:21 PM
James0013
08-05-2007 07:47 AM
furball3
01-28-2007 03:31 AM
kaltek
09-23-2005 12:22 AM
Quick Reply: Volvo s40 1 water comming from exhaust runs fine
