XC 70 Timming problem
Old 11-21-2015, 01:00 PM
Zonkball's Avatar
Post XC 70 Timming problem
I bought 2002 that had no compression in any cyl. Thought valves were bent. Removed both cams all valves seal. (Valves not bent). Put back together and had engine professionally timed with right tools no compression. Could problem be in Variable valve Timming hub on exhaust side.
Old 11-21-2015, 02:22 PM
ES6T's Avatar
Do a cylinder leakage test and see where the compression is going.
Old 11-21-2015, 09:25 PM
Zonkball's Avatar
Thanks Ill try it and let you know.
Old 11-28-2015, 06:25 PM
firebirdparts's Avatar
I have rarely seen that, but I saw it recently on a T5. It had zero compression. Tore it down and found a burnt piston (only one) and a blown head gasket. I assume the head gasket blew severely enough to let out all the compression on all 5 cylinders, but I was amazed you could mess one up that bad. I have no idea how long it ran with a burnt piston before the head gasket blew.
shore metric
05-17-2013 09:25 PM
DontaviousJones
05-09-2008 07:27 PM
nandrolone
04-04-2008 07:14 AM
turbo940
03-30-2008 11:12 AM
turbo940
03-26-2008 02:42 PM
Quick Reply: XC 70 Timming problem
