2004 Volvo S60 - Fuel Filter - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 03-21-2007, 05:22 PM
Default 2004 Volvo S60 - Fuel Filter
In the process of changing the fuel filter however can't seem to locate where it goes. Can anyone help in letting me know where the fuel filter is located on an 2004 S60. Much appreciated.
Old 03-24-2007, 01:06 PM
JPN's Avatar
JPN JPN is offline
Default RE: 2004 Volvo S60 - Fuel Filter
Greetings from Yokohama.
As I'm not privy to S60, I am not sure exactly where the FF is located and believe those in the S60 section will be able to assist you. In the case of 850, it is on pax-side, right by the rear wheel.
In case if the quick disconnect is stubborn, try twisting the fuel lines while pulling on them. Also, make sure to relieve the fuel system pressure before proceeding, I'm sure you know it.
Good luck,
JPN
Thread Thread Starter Forum Replies Last Post
2004 Volvo S60 T5 Mystery sensor in front of air filter box jekyllsdrk Volvo S60 & V60 6 09-22-2014 06:10 PM
2004 fuel filter change burrowspj Volvo S40 3 09-04-2014 11:28 PM
2004 S40 1.9T difficulty starting. Broken Fuel Pump? Bad Fuel Filter? Something Else? SecretSauce Volvo S40 2 12-04-2013 08:44 PM
No fuel filter in 2004 NA V70? hovonogila Volvo V70 4 06-06-2009 10:24 PM
2004 S60 R air filter xex44 Volvo S60 & V60 2 03-25-2008 06:39 PM
Tags
04, 2004, changing, disconnect, filter, find, fuel, located, location, pump, quick, s60, t5, v40, v70, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
