S80 troubles
S80 troubles
So my step daughter gives us a 01 S80 that just quit running , after inspection found power steering pump pulley desintergrated & serpentine belt shredded and wrapped itself around crank. After removing and replacing pump & belt engine turns but no start, will backfire now & then. Found wiring to 1st ignition coil on passengers side seems kinda melted . Could this be the problem? Is it normal for wiring to appear a little melted ? Any info greatly appreciated.
Or re-time it and then do a cylinder leakage test if it doesn't start.
