North East ME, NH, VT, MA, RI, CT, NJ, NY, PA
replace sunroof gasket?
Old 01-02-2014, 08:24 PM
thirty1emeralds's Avatar
Default replace sunroof gasket?
this past summer I cleaned out both the sunroof drains on the sides of the windshield.
I was in both a heavy rain & a car wash recently and had leakage through the upper console & on my shoulder. i looked at the ground afterwards , I noticed water coming from the area where the drains are located on each side of the car, so it doesn't appear the problem is the drains. I wondering if I need to replace the Gasket on the sunroof and if any of you had this work done or have a different suggestion.
2006 S40 AWD turbo...thanks
Old 03-04-2014, 07:03 PM
mf70's Avatar
I was just contemplating this area on my V50. It's a cool flexible gasket. If it is flexible all around and touching the opening, I would still suspect the drains.
There is a large rain gutter area beneath the gasket, with a drain at each corner. I would try testing the drains again. It should handle at least a gentle 1/4" stream of water into the gutter.
My drains were blocked at the top as well as the 90 deg bend at the bottom.
suprascooby22
02-22-2018 02:34 PM
ijourneaux
12-16-2013 12:42 AM
GrantRobertson
07-02-2013 01:49 AM
ebrobb
07-14-2006 10:35 PM
XL883L
06-27-2006 06:30 PM
Quick Reply: replace sunroof gasket?
