Penta Discuss Volvo Penta Marine Machines Within.
AQ125A Engine & I/O Prop Problem
Old 06-17-2006, 10:57 PM
jotrout's Avatar
Default AQ125A Engine & I/O Prop Problem
Hello,
I'm a new member here, and I have a prop problem that I'm stuck on. This is an I/O with relay controls to raise & lower the prop. The prop will not raise & lower. I have changed the relays but all it will do is click when I hit the prop switch. Any ideas of what to check out next? Help!
Thanks!
Joe
Old 06-21-2006, 09:17 PM
850GLTWAGON's Avatar
Default RE: AQ125A Engine & I/O Prop Problem
do u have 12volts?
make sure because if u do not then the motor will not raise
also these guys here http://www.coastsidefishingclub.com can help
Old 06-23-2006, 02:02 AM
Sounds like you and I have the same problem. I have an AQ130C I/O. I'm not quite sure what "relay controls" are. I can also hear it click and make noise but nothing happens.
Mike
Portland, OR
Old 06-26-2006, 02:30 PM
If you have someone operate the up/down switch while you go to the back of the boat looking at the outdrive from outside of the boat you will see the plunger that moves the drive up and down. try to take a flat tip screw driver and wedge it between the round plunger and the frame to help it move, then lubricate it.
Sctlny
robsvsu
02-02-2009 06:52 PM
LAD850
09-09-2008 11:38 AM
apollo
Penta
02-16-2008 07:55 PM
alireza1344
10-22-2007 10:46 PM
chipzoller
Penta
08-07-2006 11:29 AM
Quick Reply: AQ125A Engine & I/O Prop Problem
