Throttle Body To Tech/S70
Old Mar 15, 2010 | 03:12 PM
Dantheman's Avatar
Default Throttle Body To Tech/S70
I had posted and asked about the throttle body question on my S70 and the fact that it "has to be programmed to the specific car" as per the dealer and what you thought about it. You both concurred.
Before spending $1200, my husband just took a throttle body (65 mm nonturbo) out of a wreck in the junk yard that he works in, installed it in the car, took about a half hour. The car started right up and runs perfectly, no issues whatsoever, no more check engine light, no more ETS light!!! Maybe the computer just realized it was indeed a proper throttle body and said "okay" let's go with it. Hopefully, the issued is solved (I'm praying hard). BTW - the software upgrade was done under warranty three years ago.
Thanks for your input.
Old Mar 16, 2010 | 09:43 PM
I think you got really lucky!!! Fingers crossed it stays that way for you!
Old Mar 17, 2010 | 05:45 PM
Carrots's Avatar
Good luck on that throttle body... but hold on to the old one! If you ever have trouble again, there's a company called xMODEx that will repair your throttle body with a non- contact sensor that isn't prone to the wear issue that causes the problem. They charge about $550 for the service, and it has a lifetime warranty.
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
shoter_hellas
Apr 10, 2011 09:17 PM
72Demon
May 7, 2010 08:52 PM
wavewright
Apr 9, 2005 06:15 PM
