reset SRS light
Old Sep 6, 2011 | 08:25 PM
  #21
volvowife's Avatar
Iam sorry but the link does not appear to work for the instructions to reset the SRS manually. Can anyone tell me how to get them?
Old Apr 6, 2012 | 05:14 PM
  #22
mgoicea@stny.rr.com's Avatar
I replaced the front seats on my Volvo V70 X/C turbo Wagon 2.4L and the SRS light is on. Anybody has any ideea how to fix the problem visiting the dealer??
Old Apr 6, 2012 | 09:07 PM
  #23
MattyXXL's Avatar
you pay the dealer and they reset it.
Old Jan 31, 2015 | 04:39 AM
  #24
estephenson's Avatar
Default 1995 850
[QUOTE=JPN;80717]If your 850 is of '93-'95, you can reset the SRS light manually via OBD-I. However, for '96 & '97, you'd have to visit a dealer and donate $$$ as Jim has already stated.
Let us know the model year of your 850. If it is '93-'95, I can give you instructions.
JPN[
QUOTE]
Old Apr 5, 2020 | 10:43 PM
  #25
Jason Chouinard's Avatar
Default Srs 2005 v70
How about for a 2005 Volvo V70? I bought elm327 OBD2 reader...is there a specific ap that works best either android or iOS?
Old Apr 6, 2020 | 09:41 AM
  #26
there's a long list of devices and apps that scan/clear OBD2 codes. what you buy really depends on your interests and usage. As background, OBD2 codes are divided into groups as designated by the leading character ie P are power train codes, then there are chassis codes, ABS codes etc. Each computer function gets a set of codes. Next deliniation are the "generic" vs the enhanced codes. For example P0xxx are generic, P1xxxx are enhanced. Some of the enhanced may also have manufacturer specific interpretations. Finally, the OBD port is available to feed static data, ie stored codes as well as run time data - say you want to monitor fuel trim during a driving cycle...
As to the devices themselves, you can either get a handheld device with a built in screen and selection buttons or you can buy a dongle that marries up to a smart phone or PC based application. The advantage of the dongle is that the apps can be updated or upgraded as you see fit, plus you can record the data for offline viewing.
SO to your question of best app - your decision should be based on what code sets do you need to work with? every product does the P codes so the question is do you want to view chassis and abs codes too? Do you want to be able to view/interpret manufacturer codes? Do you want to be able to monitor/record real time data? Is price a consideration (these tools can range from under $30 to over $250)?
If you already own a dongle (such as the ELM 327), you can google for which apps are compatible - there's gonna be a list of free ones and others are licensed for a fee. Again back to what your needs are.
Old Apr 6, 2020 | 01:47 PM
  #27
I have a 2005 V70 and as stated I have the ELM327. It connects and can view engine details etc. but not able to clear the SRS Airbag Service code. Does anyone know of a specific ap that works with the ELM327 OBD2 reader to clear SRS code or do I have to buy a better scanner as eluded to in other posts or take to a dealer to reset? The reason for the SRS warning is I removed the psgr seat in order to take care of a water leak issue and did not disconnect battery first. Thanks!
Old Apr 6, 2020 | 06:51 PM
  #28
Well you can google "ELM327 SRS RESET" or you can swing by Autozone and "rent" a fully featured scanner. I've also used my local indy who'll scan and reset without a charge (since he knows if something was truly wrong, the code will simply reset).
copterrob
Jun 22, 2021 10:12 PM
marvgt95
Dec 28, 2009 05:14 PM
cava
Jul 29, 2006 12:27 PM
JimKW
Jul 26, 2006 08:49 PM
elbert
Jul 4, 2005 02:58 AM
