clunking noise when braking or accelerating
Old Jun 17, 2009 | 08:05 AM
  #21
bestharry's Avatar
I would replace the third bolt at the EARLIEST CONVENIENCE.
Tony -I can hear your 'meachanical engineering and force dynamics'. Its sounds hi-fi to me...:P
Old Jun 18, 2009 | 02:59 PM
  #22
weston97glt's Avatar
would it be a good idea to replace my right axle while im replacing the bolt? it doesnt seem like that much more work after you have the axle out of the hub.
Old Jun 18, 2009 | 04:17 PM
  #23
850tony's Avatar
its a very easy job to do the axle. passenger one is a little harder, but not bad at all (extra two bolts, woohoo)
Old Jun 19, 2009 | 05:01 PM
  #24
cool, thats nice to hear. The clunking is on the passenger side but i think it might be a tie rod or something. The clicking has started on the left side though when turninng.
Old Jun 19, 2009 | 06:03 PM
  #25
meb7070's Avatar
No one mentioned the motor mount on the lower right side yet. That would make clunking noises on rough road and under braking and accelerating.
Just a thought.
Old Jun 20, 2009 | 09:43 AM
  #26
Where is the motor mount located at and is it a hard job? this is my first car so im a novice at repairs, but will try it myself if it isnt too big of a job.
Old Jun 20, 2009 | 12:46 PM
  #27
blackbrick's Avatar
Maybe this can help you http://volvospeed.com/Repair/front_mount.php
Old Jun 20, 2009 | 03:59 PM
  #28
thanks! that actually explained ALOT! I feel alot more confident about doing it myself now. Volvospeed is so useful. Thats the site i used to replace my wheel bearing too.
Old Jun 20, 2009 | 04:21 PM
  #29
blackbrick's Avatar
Yes but mods here are much nicer. LOL
Old Jun 21, 2009 | 01:13 AM
  #30
Sweet T5R's Avatar
hey guys, more problems with my beloved brick. I am having trouble pinpointing a noise on my 97 850. Most of the time when braking or accelerating i hear a 'clunking' noise. It also occurs when i drive over bad, uneven roads. it is coming from the right wheel well area. i suspect either sway bar links? or maybe cv joint? i really dont have the money right now to replace more things,as im only 17 and the timing belt/water pump job needs done. so could i wait a little to replace it or would these components be urgent to replace? any help appreciated. thanks, weston.
Hey, I had the same problem!!!!! well to come to conclusion, I havent read all the posts but I work at Toyota as a lube tech :P so i lifted my car up and I see cracks on my bushings that holds the sway bar, and since its cracking it would make the sway bar lose when you turn accel or decell.
Old Jun 21, 2009 | 03:02 AM
  #31
850tony's Avatar
also the clunk could be a spring seat...
Old Jun 21, 2009 | 09:34 AM
  #32
I'm going to check the lower motor mounts and sway bar this week when its nice. Do i just check if there is play in the links and if there is they are bad, correct? It wouldnt be the spring seats since i replaced them and the strut mounts a couple months ago and the clunk from the spring seats was different than this pop/clunk.
Old Jun 21, 2009 | 01:36 PM
  #33
850tony's Avatar
got ya.
for the links. if the car is a slightest bit unlevel (driver passenger wise) the links will be tight no matter what. so get it very level in order to check. i've always been a fan of just removing one end of one link and checking it by hand for play or to be very loose. if that one doesn't seem up to par replace both. they are only $15per from fcp.
Old Jun 22, 2009 | 05:27 AM
  #34
alrite thanks 850tony, that isnt a bad price at all.
Old Jun 22, 2009 | 07:25 AM
  #35
850tony's Avatar
so u'd be looking at $30 + a lil change for shipping. at that price it might be nice to do them either way, if anything it might tighten up the front end a lil.
Old Jun 22, 2009 | 03:56 PM
  #36
yeah at 150,000 miles, a lil suspension tune up would be a good idea anyway since i dont know what was done before i bought it.
Old Jun 22, 2009 | 09:22 PM
  #37
850tony's Avatar
fair enough. if you have the cash when you do it do the sway bar bushings to. while ur in there check ur tie rods and ball joints
Old Jun 22, 2009 | 09:37 PM
  #38
alright, ill have to get out my trusty haynes manual and go at when i have the time soon.
Old Jun 22, 2009 | 09:38 PM
  #39
shuv70's Avatar
Originally Posted by 850tony
i vote the spring seat/s are bad. you can tell that they are bad if from the top in the engine compartment the black disk with the nut ontop of it is pushed up really far.
my '04 XC70 will have this pulsing noise when braking, I can also feel it from the brake pedal, I notice the "black disk " is high from the base, but not sure how far is far, to be the right indication of spring seat issue?
TIA
Old Jun 22, 2009 | 09:56 PM
  #40
850tony's Avatar
shuv70 - no that is warped rotors. go make a new thread and we can talk about it more there
weston - shoot me a pm on the swaybar work.
