Leak in Front Passenger Floorboard
Old Jul 30, 2010 | 10:20 PM
  #21
dman777's Avatar
ya, freaking sux. i never know if i'm going to have a job the next day so i'm to scared to spend $140.00 on the windshield when the duct tape works. it looks bad.
Old Sep 6, 2010 | 09:54 AM
  #22
CeeJayKay's Avatar
I had the same problem, and found out that the drainage lines were clogged with leaves and dirt. Debris came through the grates under the front windshield and clogged up the lines. Water would back up through the firewall and into the exact location you mentioned. I stuck a wire hanger up through the split in the chassis where the water is supposed to drain through. I cleaned out the passage ways and tested by filling the grates with water. When the lines were cleared, the water flowed through normally and didnt back up and spill over into the passenger seat. Dont know if you still have the problem, but if so, hope this helps!
Old May 13, 2021 | 05:47 AM
  #23
jenkinskg's Avatar
push out on windshield, mine was very loose
Old May 14, 2021 | 10:43 AM
  #24
waginc2u's Avatar
('93 240)Windshields aren't the only source of water getting to the front passenger floor. I found the floorboard itself had rusted around the plug under the car. The water was coming in from driving in the rain.I pulled up the carpet and sealed the leak from the inside with FLEX TAPE (as seen on TV). Problem solved for now.
CrowV50
Oct 16, 2013 03:56 AM
Ricardomonteban
Jan 28, 2010 05:18 PM
Tinman
Oct 7, 2009 05:53 PM
platinum_ghost
Nov 8, 2008 02:39 PM
djbaines
Jan 19, 2006 09:41 AM
