Wheel Bearing - Front (Write-Up)
Old Jun 29, 2012 | 01:23 AM
  #41
Beastman's Avatar
where would i go or what would i look for to buy one of these bearings?
Old Jun 29, 2012 | 02:21 PM
  #42
You can order one on line at FCP or Rockauto or walk into a NAPA, Oreilly, Autozone or ........ and ask for a hub assembly. Check out the difference in price and warranty and choose what you're comfortable with.
Attached Thumbnails Wheel Bearing - Front (Write-Up)-hub-assy-front.jpg   Wheel Bearing - Front (Write-Up)-hub-assy-rear.jpg   Wheel Bearing - Front (Write-Up)-hub-assy-side.jpg
Old Oct 1, 2012 | 01:40 AM
  #43
TaffyBrick's Avatar
Good Day and Thanks for this info, it sooooo useful,
Cheer's, Great Car's Huh.
Auckland.
NZ : )
Old Oct 30, 2012 | 05:13 PM
  #44
gregk's Avatar
I have some work to do..... I've got the squeak when you hit the bump (strut), the vibration when you brake (rotors/pads/bearings?) So I think I will just attempt to change them all and see how she rolls!
Old Oct 30, 2012 | 07:54 PM
  #45
Gregk, lets us know how that works out for you.
Old Jan 18, 2013 | 09:16 AM
  #46
graver's Avatar
I just replaced mine on a 1996 850r. I wanted to update this thread and mention that the hub carrier bolts are E14 NOT E16 (at least on the model I have). I ended up just grabbing an E16 and just going at it without paying attention, and stripped one of the bolts. Dont be an idiot like me
Old Jan 22, 2019 | 06:55 AM
  #47
Hedgewolf's Avatar
Default 'Mini stud'
Hi. I just got my first Volvo and this is my first post to the forum.
The OP mentioned and showed a photo of the "mini stud" being removed. Can anyone tell me the function of that part please? I have a set of wheels which would fit, if only that stud wasn't there!
Thanks a lot, take care
- Tony-
Old Jan 22, 2019 | 12:09 PM
  #48
its just an alignment pin to help set up the rotor and wheel during assembly. It just screws out (10mm). I've always removed when doing new rotors.
Old Jan 22, 2019 | 12:26 PM
  #49
Hedgewolf's Avatar
Sorry to be dense, I just don't want to screw anything up... are you saying I can safely discard them then?
Thanks so much for responding by the way 😀
Old Jan 23, 2019 | 08:28 AM
  #50
no, don't discard, just take off then reinsert during reassembly
Old Jan 23, 2019 | 09:47 AM
  #51
Hedgewolf's Avatar
Ah. That's my problem, that stud prevents me from using the wheels I have, which would otherwise fit perfectly
Old Jan 24, 2019 | 03:42 AM
  #52
tallrob's Avatar
It's just an aid. You can remove it and mount your wheels if everything else lines up (make sure they're the right size, including the lug hole depth. You need a certain about of thread engaged for these heavy cars).
Old Jan 24, 2019 | 07:30 AM
  #53
Hedgewolf's Avatar
Thanks a lot, I can see I'm going to gain a lot from joining here 👍
bobinyelm
Nov 16, 2017 09:37 PM
porkchop112699
Jan 12, 2014 02:23 PM
madymo3d
Aug 14, 2012 11:35 AM
Falasi4
May 30, 2012 09:07 PM
goodyfleece
Jun 27, 2009 01:23 PM
