Removing the dash Pad (To replace the instrument panel lights)
Old Jul 21, 2011 | 08:23 AM
  #61
clean850R's Avatar
Ok got it out everything repaired as needed. Now the dash isn't fitting the same. Hopefully some time in the sun and some pressure can reform???
Old Jun 21, 2012 | 01:53 PM
  #62
You have to pay close attention with the front edge, it fits between the plastic rail and rivets up there. Work with it, it'll go in fine.
There are usually 2 screws along the bottom of the dash pad edge that have to be removed. They may be under the felt.
Here are my instructions with pics if anyone needs to see them: http://www.atthetipwebs.com/technolo..._volvo_850.htm
I have been battleing cluster problems for the past 4 months, so I have taken mine off about 5 times.
Old Feb 24, 2013 | 08:14 AM
  #63
Toni_volvo's Avatar
Default Removing Dash pad & LED lights
One warning, if not already figured out by someone else... I have a slider on the left side of my instrument panel to adjust the lights in my dash pad. LED lamps normally can't work with that, they are mostly on or off. So when you replace your dashboard lights with LED's this no longer may work. In fact, you probably will switch off all lights completely when you move the slider to low-light setting...any experiences here?
Old Jun 3, 2014 | 07:15 PM
  #64
matthewcas's Avatar
has anyone done led's for the speedo-cluster with a pic during the night? Been thinking about this lately.
Old Jun 5, 2014 | 08:51 AM
  #65
You can Google that. Some have and made a tutorial on it.
Here is a video of the dash pad removal.
Old Jun 8, 2014 | 10:25 PM
  #66
You can take a look at this write up: 850 Led Conversion (My Experiences) - Cosmetic and Detailing - Volvospeed Forums
Disco2
May 9, 2013 02:23 AM
jrcochranusa
Feb 19, 2010 02:30 PM
jdjayakaran
Jun 24, 2007 10:40 AM
gwoodall
Jul 7, 2006 03:49 PM
