Finally Got my 95 850 Turbo wagon home today
Old Feb 11, 2010 | 11:22 PM
  #61
TIPSP's Avatar
Got Boost?
engine code. should be an ID tag, either an emission tag or vin tag, in your engine bay. It should be a B5234T
I dont have vadis installed to verify...tech should be able to.
Also check into pelicanparts.com once you get part number, which I could get once I install vadis.
Old Feb 12, 2010 | 08:19 AM
  #62
boxpin's Avatar
Originally Posted by 91shelby
also how do i find the engine code?
Should be on the sticker on the timing cover
Old Feb 12, 2010 | 07:55 PM
  #63
+1 if it is not there then you can find it on the back of the motor as well.
Old Feb 12, 2010 | 09:27 PM
  #64
boxpin's Avatar
Sticker on timing cover
Attached Thumbnails Finally Got my 95 850 Turbo wagon home today-volvo-006.jpg
Old Feb 13, 2010 | 04:11 AM
  #65
91shelby's Avatar
the tag is long gone i can see where it was. now where on the back would i find it? thanks again
Old Feb 13, 2010 | 05:41 AM
  #66
91shelby's Avatar
well i think i found why it was idling like crap. 3 vacuum lines were unplugged the 2 going for the waste gate and one going from right past the MAF sensor to a sensor. would these lines have affected it? also where is the best place to tee in a line for my boost guage?
Old Feb 13, 2010 | 07:47 AM
  #67
That can effect the idle.
You can tap into the vacuum tree on the intake for the boost gauge. But if you have a stock gauge you can tap in under the dash as well.
For the engine serial number it will be hard to see but it is in the block.If you look down like right behind the timing cover and like just below the exhaust manifold it should be there.
Old Feb 19, 2010 | 11:27 PM
  #68
91shelby's Avatar
well i finally got the parts in today to do the pcv system, the old one is definitly plugged up i cant get anything through it its PLUGGED UP lol. so im gonna clean up everything tomorrow and get that on and see how it goes. any tricks to getting the intake off to do it? or do i have to pull the intake?
Old Feb 20, 2010 | 06:47 AM
  #69
JimKW's Avatar
You have to pull the intake manifold off. There are very good instructions in the Frequently Used thread stuck to the top of this forum. I printed them out when I did mine and had them with me in the garage. Make sure you don't take the bottom bolts all the way out on the intake manifold. It's really not that easy of a job, but doable. Give youself plenty of time.
Old Feb 20, 2010 | 12:31 PM
  #70
91shelby's Avatar
what happens if i pull the bottom bolts all the way out?
Old Feb 20, 2010 | 05:44 PM
  #71
Nothing will really happen. The intake is notched on the bottom to slide over the bolts.
Old Feb 21, 2010 | 05:33 AM
  #72
garlendrix's Avatar
What year is it? Do they use the 13g or the 15g turbo?
Old Feb 21, 2010 | 05:53 AM
  #73
garlendrix's Avatar
My volvo does the same, it blows big clouds of blue smoke after idling for a while. I also have the oil puddling up everywhere on the engine especially around the plugs. I thought it was turbo seals so i baught a new turbo. the turbo turned out to be a 16t from a t-5 or v70 or something. can i still make it work on my 96 850 turbo?
Old Feb 21, 2010 | 07:20 AM
  #74
Yes that turbo will work on your car. I would do a vent system service and make sure all the vent system hoses are in good shape.
Old Feb 22, 2010 | 06:19 AM
  #75
garlendrix's Avatar
do i need to do anything with EMU's, or ecu upgrades? to run that turbo? like what if i just bolt it on right now; no mods?
Old Feb 22, 2010 | 07:58 AM
  #76
boxpin's Avatar
Should bolt on unless the exhaust housing is different. Even then you can swap it with the existing one. Bolt it on and have fun. The difference with the 16T over the 15G does not require any other modifications.
Old Feb 22, 2010 | 09:00 AM
  #77
I would do a pcv system replacement and an oil cap gasket.
You don't need any thing, the 16T should be a straight housing, same as your 96, also assuming the 16T didn't come with an angle, some did. Also, the 15G and 16T are pretty much identical.
Old Feb 22, 2010 | 09:01 AM
  #78
94/95 Turbo: conical 15G
96/97 T-5: straight 15G
97 GLT: straight 13G
Old Feb 22, 2010 | 10:17 AM
  #79
garlendrix's Avatar
Wow! Thanks for all the info everyone!
GroupBquattro
Feb 9, 2015 10:14 AM
rspi
Dec 24, 2013 01:01 PM
91shelby
Jun 2, 2010 02:54 AM
JimKW
Jan 19, 2006 10:07 AM
