Can't open door
Old Feb 19, 2005 | 03:09 PM
Georgia Boy's Avatar
Default Can't open door
I have a S90- 1997- last rear wheel drive model. The front door on driver's side will not open. All other parts of door from the inside function properly. How do I get the door panel off with out destroying it?
Old Feb 19, 2005 | 08:55 PM
Default RE: Can't open door
The door won't open at all?Or just won't open from the inside.
Old Feb 19, 2005 | 09:19 PM
Fronk door will not open from the out side-will open from the inside
Old Feb 19, 2005 | 09:53 PM
You will have to take the inner door handle trim ring off.Then the little cover exposing the screw in to grab handle to close the door and remove the screw.Then look under the bottom of the door panel and you will see 3 white clips going from the bottom towards the top.Pull straight down on those clips.The one on the front of the door panel is resessed up in there about 6 inches or so.It might be hard to get to but be patient and you will get it.Then pull out on the bottom of the door panel slightly then lift up and the door panel will come off.
Fobinhand
Sep 2, 2008 08:17 AM
vol7981
Jul 19, 2007 04:06 PM
ddriver
Jan 9, 2006 09:45 PM
