Now I need door part
Old Feb 20, 2005 | 03:27 PM
Georgia Boy's Avatar
Default Now I need door part
Thanks to Tech I got door panel off with no trouble, now the new problem. On the out side driver's door I removed the opening mech. and found the platic rocker part of opening mech. broken. Will I have to buy a new handle from dealer at God knows what price or is there a part with more integerity to replace the plastic one. As usual there is always something wierd going on with a Volvo or at least mind. Again thanks for help on the panel-would have never guessed the way to remove it.
Old Feb 20, 2005 | 08:30 PM
Default RE: Now I need door part
No problem.You can search for salvage yards in your area.If im not mistaken the working parts from a 740 or 940 door handle are the same.If you buy a handle from the dealer it needs to be painted.But you could buy one and switch the parts from the new one to your old one.Or if you can find one in the junk yard you should be able to swap the parts.
memphis
Oct 25, 2016 09:01 AM
seventeenhands
Oct 13, 2014 10:42 PM
Kiss4aFrog
Nov 20, 2013 11:19 PM
sillygily
Jan 12, 2013 02:05 PM
Sanel30
Feb 18, 2010 09:16 PM
