Is is possible to stop the seat-belt ticking sound?
Old Feb 20, 2005 | 04:30 PM
Captain Zov's Avatar
Default Is is possible to stop the seat-belt ticking sound?
I do wear my belt but if I'm looking for change for a drive-through or toll, or just stopped and want the engine running I don't like the ticking noise. Is it possible to turn it off somewhere? I tried disconnecting the plug to the seat-belt but it put on the airbag light which is probably not good.
Old Feb 20, 2005 | 08:34 PM
Default RE: Is is possible to stop the seat-belt ticking sound?
I don't think so since it is tied into the air bag system.
Old Feb 20, 2005 | 09:08 PM
Thanks. Any idea what is in the circuit in the seat belt clip? A resistor, a diode, a chip??? It isn't just a switch.
Old Feb 20, 2005 | 10:15 PM
Im really not sure haven't had one apart.
Old Feb 20, 2005 | 10:18 PM
Oh well, just another one of life's mysteries. Thanks anyway.
Old Feb 20, 2005 | 11:22 PM
Your welcome.
Old Feb 21, 2005 | 10:14 AM
cwworth's Avatar
It might be related to the seatbelt pretensioner mechanism, hence the SRS light coming on. The 'ticky-tock' box does not appear on any of the schematics I've seen but then again neither does the flashing light above the rear wiew mirror.
Old Feb 21, 2005 | 01:20 PM
Hadn't thought of that. So as well as setting of the air bag I'm risking setting off some sort of firework in the seat belt mounting! Think I might stop messing around with it.
Old Feb 21, 2005 | 02:19 PM
I just thought of another way you might be able to do it.See if you can find one of those seat belt extenders. Plug it into the latch and when you need to remove it just undo the belt itself leaving the extender in the latch assy.
Old Feb 21, 2005 | 02:40 PM
More hassle than it deserves maybe, but it's an idea. Thanks Tech.
Old Feb 21, 2005 | 03:17 PM
Your welcome it just poped into my head.
Old Jun 18, 2021 | 12:01 PM
Jambo97's Avatar
Default Ticking noise
Hi, not sure if it’s much help at the moment but the ticking comes from the fuse box in the drivers footwell, I recently bought a v40 and the ticking is very annoying so I’m trying to stop mine too, if I find the cause I will update this later
slsnumber1
Jun 2, 2012 08:02 AM
slsnumber1
May 28, 2012 12:08 PM
tastyorange
Apr 27, 2009 11:53 AM
c0mputerking
Feb 24, 2009 06:33 PM
