CR-814
Old Feb 28, 2005 | 11:54 PM
shuttleman's Avatar
Default CR-814
I'm getting ready to replace the Casette Player in my 89 780 with a CR-814 from a 91. I want to keep the factory amps and EQ but add a CD. I got an M-bus Alpine changer and adapter.
My ??? is, can I just "plug and play" the head into the old harness and then plug the amps and EQ into it? The old one only had 5 pins used in the 9 pin DIN connector.
A wiring diagram would be nice.
Suggestions or experiences?
Jack
Old Mar 1, 2005 | 09:50 AM
Default RE: CR-814
Does the 814 radio have the din on the back and a C/D button on the face of the radio?If it does and all the other connections are the same it will just be plug and play.
Old Mar 1, 2005 | 10:03 AM
shuttleman's Avatar
Default RE: CR-814
The new radio has places for the CD changer, amps and EQ to plug in, but what I'm wondering is about the 9 pin DIN wired to the flat connector on the radio. The old one had 5 wires connected and the 814 has all 9 wired. The car harness has the mating DIN with 5 wires, but it goes into a short "jumper" harness that has a 9 pin DIN on the other end with 8 or 9 wires.
I need to find a wiring diagram to understand it I guess.
Old Mar 1, 2005 | 10:06 AM
Default RE: CR-814
I don't have a diagram handy but will see if I can locate one.
Old Mar 1, 2005 | 10:13 AM
shuttleman's Avatar
Default RE: CR-814
thanks!
The "pin-out" for the radio I can figgure out. It's the car side that's tough.
jack
89 780
Old Nov 17, 2006 | 11:57 AM
banks's Avatar
Default RE: CR-814
I need hlep.............................
my CR-814 is need PIN, But i have the PIN code only need "how to key in the PIN code?"
harold1965
Jan 29, 2011 07:15 PM
volvopilot
Jul 2, 2008 01:34 PM
