HVAC Fault
Old Mar 2, 2005 | 01:02 PM
Air Defender's Avatar
Default HVAC Fault
The RECIRCULATION and AC OFF lights are flashing after start up. The owners manual says that this indicates and HVAC Fault. It does not do this everytime I start-up, only randomly. Also everything appears to work during this time. I can cycle the AC on/off, turn recirculation on/off, adjust the temp, adjust the fan speed, and the auto functions appear to work. How can I determine what is causing the "fault"?
Old Mar 2, 2005 | 01:11 PM
Default RE: HVAC Fault
I forget what year your car is but you will need to pull codes from the A/C system.
Old Mar 2, 2005 | 02:24 PM
It is a 1998 S70 GLT. Can the codes be read with a regular code scanner or is this some Volvo thing?
Old Mar 2, 2005 | 02:29 PM
I think you need to have Volvo do it unless you have a real expansive one that reads A/C codes.
v1lcins
May 20, 2022 10:53 AM
Maxbaby
Dec 24, 2011 09:38 PM
tn850
Dec 5, 2007 07:20 PM
Maxbaby
Apr 18, 2007 03:16 AM
850forum
Feb 25, 2007 01:51 AM
