Volvo 850 Est Lighting Electrical Fault
Old Oct 21, 2003 | 05:26 AM
GaryW's Avatar
Default Volvo 850 Est Lighting Electrical Fault
Ihave a Volvo 850 TDI Estate. Recently it developed a problem where the headlamps and tail-lights do not turn off when the ignition is switched off and the key removed. This happens when the switch is set to OFF and FULL-ON. If I leave the switch in the middle position then the headlamps turn off but the tail-lights stay on brighter. It is draining the battery and I am having to remove the light switch to slow the battery drain.
So far I have replaced the light switch. This seemed to work for a couple of weeks before the problem started again. Since then I have replaced the Light Control Relay. This has not helped at all.
Suggestions of what to do next please.
Regards ... Gary
v1lcins
May 20, 2022 10:53 AM
graeme_nash
Sep 27, 2018 08:11 PM
Vmax
Dec 4, 2013 06:19 PM
texan_176
May 26, 2011 10:34 AM
quattroped
Oct 25, 2010 02:46 PM
