hissing noise at brake pedal...
Old Mar 9, 2005 | 03:54 PM
kaz's Avatar
kaz
Default hissing noise at brake pedal...
Hi there,
I just notice this recently, sometime when i step on the brakes brifely and let go (like in traffic jam). there's a faint hissing noise coming from my brake pedal, but if i step on the brake pedal the noise stops until i let go again....on the other hand, if i step on the pedal really hard then let go, the noise stops completely. sounds like somthing leaking?? and there's no noticeble different in braking performance and distance.... weird[&:]
FYI: I got my brakes serviced in Nov last year: new brake pads all around, drain, fill and bleed system with dot 4 fluid.
Any help will be greatly appreciated
Dan
Old Mar 9, 2005 | 04:21 PM
Default RE: hissing noise at brake pedal...
The diaphram in the brake booster is bad.You will need to have the brake booster replaced.
Old Mar 10, 2005 | 01:17 PM
kaz's Avatar
kaz
brake booster... is that the same as brake cylinder??? how much $$$ is that?? can i do it myself??
As of this morning, there's no noise coming from the pedal, and i'm stuck in traffic every morning... will this eventually affect my brake performance??
Old Mar 10, 2005 | 08:28 PM
The brake booster and master cylinder are diffrent things.If you have patiance you can do it.It is a pain you have to disconnect the battery and move the front fuse box.
Old Jul 7, 2006 | 01:11 PM
gordon368's Avatar
Im at volvo right now and i think the service guy said it be around 750$ for it.....
petax
Jul 2, 2012 06:21 AM
stunna7516
Jun 16, 2011 10:43 AM
mk_s40
Sep 5, 2009 07:49 AM
rchen404
Nov 11, 2008 07:34 PM
xxjoeyxxeb
Oct 3, 2007 04:05 PM
