V40 Running Problems
Old Mar 16, 2005 | 11:29 PM
edisonbelle's Avatar
Default V40 Running Problems
Can anybody Help?.
2000 V40 SE. When driving at any speed the engine revs will just suddenly drop and then recover,the engine managment light thinks it a indicator, on for a few days and then switchs off, the emisons fail the MOT tse and finally eats Headlamps and tail lamps.
Volvo Dealer Recomendations after resetting EM light was to replace the Lamba sensor, its had two in two years. Any ideas !
Old Mar 17, 2005 | 12:01 AM
Default RE: V40 Running Problems
Do you know what codes the dealer pulled? If so post them for me.
Old Apr 19, 2005 | 05:33 AM
I've finally got the code EFI001 Suspect oxygen sensor fault.Any ideas
Old Apr 19, 2005 | 10:36 AM
Im not sure which market you are in.In the Us they Have an updated O2 sensor harness that going into the o2 sensor.You might need that harness installed.
Old Apr 19, 2005 | 02:40 PM
I'm in the uk & its a uk car
Old Apr 19, 2005 | 06:00 PM
Ask your local dealer and see if they had it there as well.They were installing the harness due to causing the light to come on sometimes when there was no fault.
azeli73
20
Dec 31, 2019 10:59 AM
ridejoeride
Jul 12, 2010 08:03 PM
S70driver
Dec 6, 2006 01:53 AM
Midnight_Caller
Aug 29, 2006 05:40 AM
acldrwd
Oct 14, 2003 09:25 AM
