s70 hood won't opend ????
Old Mar 19, 2005 | 10:28 AM
peterz's Avatar
Default s70 hood won't opend ????
After pulling the hood latch lever inside my car the right side of the hood pops up a little but the left side remains down. Using the under hood latch does not release it. Any ideas on how to open hood or fix problem?
1998 s70
Old Mar 19, 2005 | 12:10 PM
Default RE: s70 hood won't opend ????
Some times they are picky.Have you tryed having someone pull up on the hood while holding the release back?The hood release is a weird set up one cale releases 2 latches.Sometimes the cable stretches some and it is a pain to open the hood.I always keep a wooden wedge in my tool box for just such an occasion.You might have to play with the cable adjustment.First try libbing the heck out of the latches.Another thing you can try is using a pair of pliers carefully pull a little more on the cable inside the car once the handle is pulled all the way.
Old Jan 24, 2006 | 07:24 PM
mo t5's Avatar
This is a shot in the dark, but my hood is doing the exact same thing. I took a small washer, cut a small groove in it. Then I pulled the cable ball away from the lever and slipped the washer between. I then took a pair of pliers and squeezed the washer shut. This is a cheesey way to make it work but it makes the cable a little longer. Sometimes it takes two little ones or one big washer. I am the redneck volvo repairman.
Old Jan 31, 2006 | 12:56 PM
mo t5's Avatar
Don't do what I sugjested, I did it and now my left side latch won't latch the hood down.
Old Jan 31, 2006 | 10:10 PM
JimKW's Avatar
I have this problem on my V70. What works for me is that when only one side unlatches, I push down real hard on the hood and then go pull the inside realease again. It usually works after doing this. If not I have somebody lift up a little on the hood while I pull the release inside.
Old Jan 31, 2006 | 10:15 PM
We have messed with cars like this alot and adjusted the latch some and can get some of them to work.
Old Jul 22, 2010 | 09:54 AM
t5ftw's Avatar
I slide a wooden cloth peg under the grill then go pull the lever.
Old Jul 22, 2010 | 12:51 PM
xxblindxx's Avatar
My car does the same, takes me about 5 mins to open it my self going back and forth. much easier if there are 2 people haha
Old Jul 22, 2010 | 07:15 PM
My S70 did that once. I adjusted the bumper stop on that side to put a little more up pressure on the hood and it has never done it again. Just a slight adjustment.
Old Jul 27, 2010 | 09:55 PM
t5ftw's Avatar
I just got a socket extension set for no reason, and looked for what I could do with them. I gave it a try and adjusted it downward slightly.
That fixed it. wonderful! thx
Old Nov 16, 2013 | 11:19 AM
xc90volvo2003's Avatar
Default 2003 xc90 hood won't release on one side
I'm having the same issue on my 2003 xc90. One latch releases and the other stays locked, but I can't get the side that releases to lock again. Should I try the suggestions above or use a different approach bc it's a different model?
Thanks!
JeannieBeannie
Mar 6, 2019 01:29 PM
MDUBBSS70
May 28, 2014 09:02 PM
Red Tractors
Aug 20, 2013 10:33 PM
drneville
Jan 25, 2009 10:41 AM
850TurboWgnPlatEd
Nov 5, 2008 12:52 PM
